Hi all, I've had a major problem with a taste/smell contamination from new washing machine hoses fitted to my Hotpoint which has separate hot and cold fillers, the hot from the combi (new last year)
The problem started when the old red hose started leaking and I went to Screwfix and bought the replacement. The hose looked and went on and worked as it should. Over the next few days we started getting a chemical taste off the water. We thought that Scottish Water had been working on the mains and this was just excess chlorine that would clear.
After a week the taste/smell from both the hot and cold taps in the kitchen and bathroom was too much to stand so we called SW and they came out to check the supply. My neighbours all had perfect water so it was surmised that we had a lump of the chlorine in our supply. We flushed all the taps for 24hrs and SW flushed the mains.
The problem wouldn't go away and SW came back and ran the mains for a week with no improvement. The taste and smell was still there. I read on the Water companies' pdf that contamination could come from washers reacting with the chlorine and phenol.
As an afterthought to that I suggested that the problem had started when I replaced the hose, but several plumbers told me that the taste/smell could not migrate against the incoming flow so it couldn't be that. I took the hose off anyway, and within 10 minutes the water had no taste/smell.
Thinking that Screwfix had a duff batch of hoses I bought one from Toolstation, put it on today at 3.30pm and made a cup of tea with fresh water at 4.30pm, the tea had a taste, I ran the water and it had a chemical taste and smell similar but different to the last hose. I took the hose back off and the taste/smell was gone in 10 minutes again.
The hose smells terrible, which it didn't when put on. The strong smell is from the washers, though whether they or the hose itself is the cause I don't know.
I know that I have found the source of the contamination as the hoses were the only thing changed in in the last 5 years and there is no smell or taste from the original blue hose. Has anyone heard of this before? I can't believe that of all the hoses Toolstation and Screwfix sell and plumbers install that I have been unlucky enough to get two mingers in the same period.
I'd also value an opinion as to why the taste/smell can migrate from a hot hose back through the boiler and into the cold feed. According to long served plumbers this can't happen. I know it does because it has, despite all taps and appliances being fed from mains water. (ie no tanks in loft etc)
How the heck do I get a hose/washers now that won't have this problem as the Water companies suggest using Kite Marked ones. No plumbers Merchants/Toolstation/Screwfix have any that has the Kite Mark so I presume they all come from China these days. Any thoughts? Thanks in advance
