In recent weeks I have gone through the nightmare of learning about the reaction that takes place when the chlorine that is in the water, supposedly reacts with hoses, tap washers and stop tap washers. It began when using the dishwasher everything that came out had a foul lingering for days smell. having thoroughly cleaned and disinfected the DW the smell continued. All of the waste was thoroughly cleaned and hosed, the problem continued. I then changed the dishwasher (it was five years old) to another, which was only 18months old and had not previously been a problem when used elsewhere. In spite of all my efforts the result was the same, Foul smelling crocks.
I then washed everything up in the sink, using very hot water from the tap and found I had the same problem. At the same hot drinks tasted awful. I contacted the water Company in desperation, really stressed by these events.
They advised me to change the tap washers and told me that the washers could reacting to the chlorine in the water supply. I was further advised to fit non return valves to the hose for the Dish washer and finally to replace the washer in the stop tap. These last two jobs have yet to be carried out. I have discovered that there are approved fitting via WRAS as many of the fittings taps /washers ect. available on the high street will not tolerate the chlorine and will cause this reaction with the water. These jobs are costly and inconvenient and take a long time to resolve, when starting from scratch. I am told that water samples taken by the water company have proven to be safe - although the water was not tested at a heat consistent with hot water from the tap or the temperatures achieved in the dishwasher. I have not noticed any problem with cold water it is only evident when really hot.
I have never been made aware of this potential problem and have purchased many fitting over the years with no problems at all.
I am hoping that when these last two jobs are completed my problem will end, however, I feel frustrated and I would suggest that most of the public will not be aware of this and will be equally frustrated in times to come, because there is nothing to create awareness of this problem. I buy a tap because I like it as most do, I do not be the cheaper brands, I might replace a washer, but I wouldn't be aware that it might be the wrong washer, it is an outrage I think, should we ask "will this tap or this washer or this hose, tolerate the chlorine in the water supply" For sure I know what the answers would be!
