Hi guys,
Nearing the end of a full renovation of a property I started at the beginning of the year.
When re rendering/plastering the internal walls, I neglected to remove the render from a damp upstrais chimney breast.
I fixed the chimney, (repointed, flaunched, vent caps installed and new lead flashing)
However I did not remove the damp/cold to the touch plaster/render.
It was skimmed over and the damp appears to be showing through.
My question is do I need to remove everything on this back to brick, or will one of the stain/damp block paints be enough to stop the stains showing through?
Also - as the chimney is now presumably drying, if left untreated would these stains eventually disappear?
Thankyou!
Thankyou!
