- Joined
- 27 Jan 2008
- Messages
- 28,484
- Reaction score
- 3,459
- Location
- Country
Two questions about solar panels.
First is the disconnection in the case of power failure. Where a whole street with all houses fitted with grid-tie inverters is disconnected from grid how do they know the connection has failed? One is simple two becomes a little more of a problem but when we reach 10 how does it work?
The second is volt drop we are allowed +10% -6% and I would expect the transformer would sit no load at 253 volt so when one full load the furthest user will still get 216.2 volt. However with grid-tie during the day when all occupants are at work the inverters will want to push power back into the grid. So the transformer would need to sit at 230 volt to allow that otherwise the inverters will all close down due to over voltage.
I am guessing the two are related and the 2 second disconnect and 3 minute reconnect will ensure that either under or over voltage will shut down inverters in turn until last one shuts down.
So although today I may fit solar panels and they all work A1 in a couple of years they may fail on a regular basis although there is nothing wrong with the system.
There are two ways to get solar panels on ones roof. One is you buy the system the other is you do a deal to allow your roof to be used. With the latter when the panel is working all you use is free. But you don’t get the feed in tariff so all feed into grid the installer gets.
Clearly the installer wants to get paid and unlike oneself who has to pay someone to maintain the panels they will have their own team so getting the voltage set at 254 will insure their panel is last to switch off. Which means those who fit their own will have theirs fail more often.
Also a large firm can put more pressure on the DNO if the voltage is regular high and will also have the monitoring equipment to know when the problem exists.
At the moment I am waiting for a report to if my roof is at the right angle for free panels to be fitted. If not then clearly not worth me fitting anyway but if it is then do I go for free panels or fit my own. If in the future there is going to be problems with so many being fitted then best going for free ones. However if I can be assured that it will not fail in the future than better buying my own.
Thoughts please.
Thoughts please.
