Hello,
I have a 30s property with a poorly built lean to on the back. I've blocked up the outside toilet part of it and I'm extending our pokey kitchen out into it.
I have about 1/4 of the floor removed and I'm about to fill it with concrete to get a base to work from. There doesn't appear to be any DPM or insulation of course, but I'm not sure I can afford/stomach replacing the whole thing. It has moved/cracked a little over the years so this is my plan:
On the 1/4 missing floor lay a DPM and fill it with concrete. Then I'm wondering can I put another DPM across the whole floor and use a self levelling screed on top of it? There will be no insulation but I'll have to live with that. I imagine the screed on the DPM will be fragile so probably a rubbish idea?
I want to finish it in an engineered wood, but I'd like to minimise the raising of the floor if possible.
Any tips would be very much appreciated, rubbish photo below for reference.
Thank you
Russ
Thank you
Russ
