Hello all,
Ok I'm trying to insulate my lean to, and currently having a go at the ceiling.
I had 3" rafters, but wanted 100mm insulation so I've extended them down by about 30mm. The felt seems ok but I'll probably refelt it with something more modern (it has bitumen stuff at present) Between the original rafters I've wedged the 100mm celotex.
I believe I'm supposed to make it air tight, should I foil tape between the celotex and joists before I plasterboard it?
The joist extensions leave a slight gap in some places by the celotex. Should I try and get some expanding foam in there? Sounds bloody messy if I can get it to stay up.
I'm considering an insulated plaster board (35mm backing I think), or maybe OSB first then normal plasterboard for the ceiling and the walls, worth doing?
Thanks for your help,
Russ
Russ
