I thought I would revive this post to update what has happened since, and it aint good
During the summer not that long after the boiler was fixed, I noticed the tank was overflowing (albeit very slowly). Upon investigation I found a tiny pinhole in the dhw coil, right below where the heated boiler water enters.
Albion technical where less helpful than a chocolate teapot (at least you could eat that) saying, tough mate tanks knackered you need a new one. Stuff that I thought, so set about plugging the hole with solder, and to my amazement to this day it is holding.
However the story unfortunately does not end there. A couple of weeks ago the cold forced me to relent and put the heating on, I so wish I hadent. Within about 15 minutes, no less than 3 radiators sprung a leak, one of which flooded my daughters bedroom and ruined the lounge ceiling.
I have had my pro plumber round, he reckons I should ditch the thermal store, fit an unvented tank and if the pipework will take it a sealed system, and if not a feed expantion tank in the loft. He thinks the water in the system is getting oxygenated either by a leak in the system or from the feed from the boiler dragging air in at the top of the tank (it comes in about 5-6 inches from the top of the water level). Ironically I flushed it thoroughly in July, and added 4 bottles of fernox which would give a concentration of 5-6%
Frankly I just want the thing sorted, I have now lost 5 radiators, 1 towel rail and two boiler exchangers which is rediculous, but somehow I dont want to give up on the thermal store system, when it works correctly it is fantastic, and I cant beleive my plmbing and the design of the store is so bad that so many rads etc have popped. (And of course I want to be sure it wont happen even with a new system).
Sorry this is such a long post, but I am so fed up with the whole thing I could really use some helpful opinions.
Many thanks!
Many thanks!
