gas water heaters
1 Dec 2013
Cumbria
Hi to all as this is my first post on the forum.
My wife has inherited her grand parent's (deceased) house recently. It's a very solidly built (probably) 50's built 3 bed semi.
It's in a time warp and needs a new kitchen and either central heating or maybe storage heaters fitting as it has nothing at present. The old folks relied on a gas fire in the living room and the electric heaters in other rooms
My question revolves around the water heating. In the airing cupboard is a standard copper tank without an electric immersion fitting, and by its side is a gas burner device that obviously heats and circulated the water to the tank. It has a flue that goes straight up into the loft space, and presumably out via the roof. It looks like an antique to me, what do the gas fitters think, is it a bloomin danger that will probably likely set the place on fire or boil the water up one day when people are out or are they OK? The other issue I guess is that spares will not be available. We plan on renting out the property in the future as no buyers have expressed interest as yet.
Julian
Few younger gas guys will ever have seen a circulator even in there day they were not very popular.
Spares definetly not avialable as not been made for around 25 years.
Needs a air vent directly to outside from the cupboard or cupboard doors vented then a vent to outside in that room .
There was various thermostatic protection on models but yes it could boil over if these failed , Fire only under extreme circumstances or someone put stuff too close in cupboard
Rented out property i personally would get it disconnected and removed as not worth the risk at the age it is .
Thanks Gas, that was practically the reply I was expecting to hear. Basically it's to go in a skip!
So the next question now looms: We have a choice of gas or electricity for heating/hot water.
I think the economy seven convectors and large DHW tank are pretty good these days, but I wonder if it would put off potential purchasers as the average bod just equates electricity with expensive and probably can't quite understand the workings of the economy 7 tariff?
So onto gas, I'm really not a fan of combi boilers as I just see needless complication and the inevitable breakdowns and expense. Has the combi boiler got reliable of late or not? Conventional boilers are probably more reliable, but am I correct to think that they're not allowed as replacements nowadays and condensing types must be fitted?
So basically, what would people do if starting off with a clean sheet in an old three bed semi? I'm not after fancy 'bells & whistles' cobblers, just basic heating and hot water to make the house more saleable and/or attractive to tenants.
Cheers Julian.
I would forget the E7 storage heaters. They are expensive to run, bulky and offer poor control. Maybe modern ones are better, but when I lived in a flat with them, they were cooling down late afternoon/evening just when you wanted the heat. If gas is available, it's always preferable to electric. Tenants will almost always feel the same.
If you don't like combis, you can have a heat only boiler and stored hw in a new hw cylinder. Whether you have heat only or a combi, they are all condensing these days.
Also, a few snaps of that circulator would be good. ;)
That's the way forward I think, heat only and a new storage tank with immersion that's invaluable if the boiler packs up. Conventional motorised valves etc.
One thing with the gas option is the requirement for an annual safety check thing, which as a landlord is an additional cost, but probably not that much in the overall scheme.
I'll try and take a few pictures of the circulator next time I'm there.
Julian
Couldn't agree more...just replaced my elderly mothers storage heaters, new house for her and they were replaced 3 years ago but so inadequate in control and cooled down in early evening when she really needed heat, such a waste of money. 2 new thermo ceramic rads and economy 10, so much better and cheaper!!
Thanks Julian. I've heard of them, but never actually seen one installed. Looks like an extremely simple bit of kit. Not much to go wrong.
Unless it is fitted to a direct cylinder in a hard water area. I've seen the bore reduced to a pencil sixe. To be fair, you know about it, as it sounds like a train
Indeed, they look really simple. I've no idea how they work but there doesn't appear to be room for a conventional 'gas valve' as you would find on a conventional boiler. Maybe there's just a pilot light and a bi-metal strip controlling gas flow to the burner, some sort of flame failure device too I expect? No mains power to it by the look of things.
Julian
