Paragon turbo plus
29 Mar 2013
Merseyside
Hi, I have a paragon turbo plus fire. Approx 14 years old. Question is can the newer heat saver fan be fitted, as the draught from the standard fan is bad and when it's been really cold the house never warms up unless put the fire on very low just to stop the draught. Thanks
YES, it can be retro fitted. Whether it can go back that far, I wouldn't guarantee. If you can, they are reasonably expensive, as you have to change the entire fan unit, rather than just firring the fan saver flap. But they DO work well, and I rarely quote for the basic version.
Try phoning Technical on 01952 217 512 for availability at that age. Rob is best if he is available. Good luck.
I think I may have one complete new fire going (relatively) cheap. Would have to check stock.
Many thanks - if you would like to give me a call during the day please ring 01282 418317 Thanks
