I'm looking to run some cable for some outdoor lighting to be installed at a later date. (Patio lighting)
Will the following work ok as I'm going to run the cables myself and then get an electrician to wire them.
Run 1.5mm T&E from fuse board to switch and then 4mm 3 core armoured from switch (located indoors) to a adapter box outside where I will terminate it until I'm ready run further cables from the adapter box for the outdoor lighting.
I would then like to also run a 1mm 3 core cable from the switch (indoors) to a second location indoors so that I can effectively operate the adapter box (outdoor lights) from 2 switches.
Can anyone see any issues or advise before I go buying and running cables?
