Hi
A semi-productive weekend of DIY. Got the new waste, trap etc fitted to the bath and moved on to the tap once I was happy the waste wasn't leaking...
I removed my almost 30 year old mixer yesterday after much swearing and loss of skin. I have a new thermostatic to fit and I thought it would be fairly straightforward (well of course!).
When I got the old one off I realised that the deck pillars for the new one (grohe 3000) have about 10 of extra thread on them.
I see two ways forward:
1) Cut the threads on the pillars. Only possible problem is that the cut will have to be perfectly square to provide a good mating surface for the fibre washer.
2) Cut the existing feed pipes and replace with either new rigid sections (beyond me) or compression fit flexi tails (think I could handle this).
Which would you do? Any tips on cutting the pillar thread square if I go this route?
Attached are some pics. Access is a real pain so if new copper was to be soldered in it would require a very slim and fit plumber!
I'm not sure there's enough clearance but if anyone can give their opinion before I potentially call out a plumber that would be helpful.
Some pics:
Any advice from the pros greatly appreciated.
Cheers
Some pics:
Cheers
