Hi, I've been having problems on my central heating system, in that I've flushed the system twice, and then added Sentinel X400, but three weeks later one radiator is still not getting hot, only tepid.
I was originally told that the pipes were full of sludge, due to being non barrier plastic pipes and that's why I added cleaner and flushed and although I've got the water in the system clean and all of the other radiators working well, it appears to me that the return pipe from the last radiator on the system is blocked.
This pipe is behind the drywall and I'm loathe to re-pipe unless all other options have been expended.
I've read that using a power washer is an option, but obviously not back through the boiler and pump.
I can access both ends of the pipe, so my questions are:
1 -Is the power wash an option ?
2 - What's the best method to connect it - what adaptor, how will the pressure build up if I just connect directly?
Any advice would be most welcome.
