Morning all,
I'm going to be installing down lights and would appreciate some advice.
My current set-up is as follows -
One 2 gang switch controls 2 ceiling roses, each one has 3 spot lights which can be switched on and off by the 2 switches. So, half the room is lit or all is lit.
I propose to take each rose postion and install 4 downlights in it's place. which are still controlled by the 2 gang switch. retaining the half and half lighting ability.
Can someone help me out with understanding the wiring mods that will be required, my understanding is as follows -
Take the rose postion and place wires into wago box, from this box daisy chain the 4 downlights. The switch will still function as normal and control the 4 downlights instead of the rose - correct?
