Procombi Exclusive 30
21 Jan 2014
Blackpool
Any views/experience of the above boiler?
Been told this is a decent mid range model to replace an existing, (faulty), Jaguar 24Kw.
Any comments/recommendations appreciated.
I have fit roughly around 80 of these and only had 1 problem so far. The diverter valve was sticking and the hot water was passing through the heating circuit. I phoned up their technical team (ideal) and they came out the next day to replace the part. Like i said ive fit many over the past couple of years and i haven't had a call back yet! They were designed by 3 gas engineers and they made it easy to install/replace parts! They put a 1.1 gas valve in the boiler so it can cope on full burner rate at a minumum of 14 mbar which is ideal for a conventional boiler swap without having to alter the gas main (most of the times)
all in all a great boiler for the money in my eyes and not had a unhappy customer yet!
So you install boilers with more than 1.0 mbar pressure loss in the supply pipe?
And a supply at the boiler of less than 18 mbar?
Tony
