Replacing a fused spur to serve underfloor heating
What rated circuit would this be fitted to and what is the rating of the accessory/switch/not the protective device the actual current the unit can deal with? i don't think a BS646 is suitable for circuit protection and you should down fuse with a BS1361 prior to the fitting of this unit.
Thanks for the swift reply. I'm afraid I don't know what the current the unit can deal with is and it isn't obvious from the manufacturer's website. The fused spur I would like to replace was added by someone else to the upstairs lighting circuit - I'll check the RCD but it's probably 5A protecting the whole circuit.
You were asked what current does the UFH draw.
Yes, it's a light switch but that was not what was asked.
Are you sure?
That would be silly for an UFH.
Irrelevant and unlikely.
The MCB may be 6A for a lighting circuit.
You should not replace a FCU with a timer. It should be additional.
Programmers and timers for UFH are available; why do you want to use a light switch?
That was the first half of the question 'what is the rating of the accessory/switch/not the protective device the actual current the unit can deal with?' Is the question I answered.
Again, my reply relates to the second part of the question.
Are you sure?
I’m certain – even if it is silly. Tripping the lighting circuit trips the UFH.
I already have it so would like to know if I can use it. If there’s an issue with safety then I won’t and will look for a more appropriate bit of kit. There’s an existing thermostat at floor level. I’ll look to see if I can replace this with a combined timer and thermostat in one unit thereby not removing the FCU.
I had a change of plan for anyone who reads this thread in future. I've replaced the existing thermostat with one that offers all the features I need. No changes to the existing wiring needed. :D
