Hi
We recently moved and the boiler in this house is giving us problems. We replaced the pump to see if this improved things but it didn't. There are 2 room stats, 1 upstairs and 1 downstairs. When we put heat only on, the upstairs heat comes on only lukewarm but downstairs get hot. Also before the temperature reaches the downstairs room stat selected temp the boiler cuts out, then restarts after about 5 mins. We are going to have the upstairs heating zone valve replaced but even when we have only heat to come on downstairs the boiler cuts out after an hour and hasn't reached the room stat temp.
The only way we can make the heat come on properly upstairs is to close all the radiator valves, then start opening them up 1 by 1. Not ideal.
Can anyone help as we don't know what's wrong..
