Helps prevent!It's not messing around, it's one of the several specified ways of meeting the regulation, and the only one which prevents damage to the cable when drilling.
If you really tried hard, that prevention could be breached
It was you, not me, who introduced the 'messing around' phrase - I would probably have used different languageGood point.Someone presumably needs to 'mess around in the CU' to install the new sockets circuitIt's not messing around, it's one of the several specified ways of meeting the regulation, and the only one which prevents damage to the cable when drilling.I would regard that as definitely preferable to messing around with 'mechanical protection'
Although you may think it be more logical to install a new dual RCD consumer unit with regards to the costing of components. The bigger picture will incur installation costs and the recommended, notification fees as well as the costs for inspection, testing and reports/certification.
This would be all relevant, if costing up and trying to make a logical informed decision on whether a swap out is the best way to go.
To what benefit?would it still be worth buying the new consumer unit for £70, taking out 1 RCD and 1 MCB, and keeping the rest of the consumer unit complete with 1 RCD and 9 MCB's for spares?
You can buy a gas boiler at B&Q but it's not legal for you to install it unless you are GasSafe registered.I just saw this on Screwfix, the same consumer unit as mine, but with 2 rather than 1 RCD. Presumably they wouldn't sell it if it wasn't currently legal.
Last time I used steel plate it was easier than I thought, just 2 minutes on the angle grinder and 4 holes, then 10 minutes with the SDS. Plate held the cable in place so no need to clip.[I would personally regard the obtaining, cutting, preparation and attachment of such protection for each and every relevant cable drop to be much less preferable (much more time-consuming, and much more of a 'fiddle') than simply swapping the MCB for an RCBO (assume one will fit), whilst I was necessarily already working within the CU.
There are, indeed, swings and roundabouts - so opinions will obviously vary. I have merely indicated which would be my personal preference in the situation we're discussing. I may be wrong, but I would suspect that most electricians would probably share my preference, rather than yours.Last time I used steel plate it was easier than I thought, just 2 minutes on the angle grinder and 4 holes, then 10 minutes with the SDS. Plate held the cable in place so no need to clip. ... I'm not familiar with MK boards but I've found it usual to have to remove the busbar to get the new unit in/out, which can take time. Plus you're working around live incoming tails on that side of the board. Also there is a risk the OP has a borrowed neutral on the landing which will lead to problems when he replaces the MCB for RCBO.[I would personally regard the obtaining, cutting, preparation and attachment of such protection for each and every relevant cable drop to be much less preferable (much more time-consuming, and much more of a 'fiddle') than simply swapping the MCB for an RCBO (assume one will fit), whilst I was necessarily already working within the CU.
That doesn't surprise me, and it's obviously another reason for not going for the 'mechanical protection' route.I'm not convinced that even 3mm mild steel is adequate mechanical protection. I just tried drilling some with a 5mm masonry bit - took about 3 seconds per hole. It would probably be easier if buried in plaster, which would stop the drill skating around.
I agree, which is one of the many reasons why I personally would not rely on 'mechanical protection' of cables (unless it were ridiculously substantial protection).In my experience, when drilling a wall it's not at all unusual to find a hard spot - a piece of aggregate or something - that needs a bit more time and pressure on the drill, so I wouldn't assume the lack of progress meant I'd found a mechanically protected cable.
