Boiler switch off every 2-3 minutes. Advise needed please, below is system speciffication
System is fully pumped S plan 3 zone with Honeywell Auto-bypass valve following are the specification.
Boiler: British Gas 330
Pump: Grundfos Pump
Valve: 2 into Honeywell 22mm 2Port valve &1 into 28mm 2port valve: 1>Heating Downstairs. 2>Heating Upstairs. 3>Heating Hot water.
Programmer: Drayton 742R Mitime programmer
Cylinder stat:Wired Drayton Cylinder stat
Room Stat: No Room stat
I have wired as per system specification as below.
Pump: Grundfos Pump
