Unvented S Plan System with 2 heating zones
Danfoss WB12 wiring centre
Danfoss TP9000 programmer with Danfoss TS2 temperature sensor zone 1 C/H and H/W
Danfoss 4 wire 2 port valve C/H zone 1
Danfoss 4 wire 2 port valve H/W
Range Tribune Cylinder with tank thermostat and immersion heater
3 speed pump
Honeywell CM907 programmer zone 2 C/H
Honeywell 5 wire 2 port valve C/H zone 2
Ideal Logic Heat 12 boiler
This is the make up of my heating/hot water system. Following the change of the head/motor on the Zone 1 C/H 2 port valve, I no longer have control of my heating via the TP9000. The programmer lights up and works for H/W but the boiler will not fire. If I over ride this at the 2 port valve the heating works.
I am hoping that the collective wisdom can tell me just what it is I'm missing, its driving me mad LOL
Thanks in advance
3 speed pump
Thanks in advance
