I recently (6 months ago) had a blue brick damp course done, with moisture resistant boards (drywall? Not entirely sure) stuck to the walls before being plastered.
Not less than two weeks after the job was finished, damp patches started to appear on the wall where the boards join together.
After getting nowhere with the company that did it, I thought since the patches were small, some Ronseal damp seal will do the trick, so I used some and then painted. However - a couple of weeks after that, the paint start bubbling at the damp parts.
I have two questions:
1. What did they likely do wrong for it to be "leaking" between the moisture resistant boards within a couple of weeks of the job being finished?
2. Will permanently fixing it require knocking the plaster off and putting some special compound between the boards, and then replastering?
Here is a photo of the wall up-close:
http://imgur.com/iYOulRu
Thanks in advance for any advice or information.
