Hi, have an issue with the upstairs bathroom toilet. When flushing, bowl fills up and takes an age to drain. It does eventually drop to normal level.
Now, the other thing which could be a complete red-herring is that I've recently noticed a drip coming from the outside guttering where the outside soil pipe connects with the down pipe approx 6ft from ground. It seems to be a normal water leak, but then I remembered that it hasn't rained for a couple of weeks. Is this leak related? Also noticed some discoloration of the bottom of the downpipe.
Outside kitchen gully drain is also filling up. Level dropped after using soda crystals but does rise again.
I'm reluctant to plunge the toiler bowl in case this makes matters worse.
I also have no access to man-hole cover.
Thanks in advance.
Thanks in advance.
