I want to replace old twin cables;
One twin cable has a Thick Red pvc outer sleeve inside that is a smaller thinner Red pvc coated single copper core wire, the other wire is a smaller pvc green coated single copper core wire
One twin cable consists of a Thick Black pvc outer sleeve with a thin green stripe on the outside covering a smaller black pvc single copper core wire the other wire is a smaller pvc green with thin black stripe coated copper core wire.
Question: Would you replace these; for lighting with 1.5mm flat grey twin and earth. I prefer 1.5mm for lighting; the 1mm looks a bit flimsy.
Question: I cannot find any twin cable that would do the job properly, is twin lighting cable available; if so who supplies it.
I look forward to your input.
