Build over Thames water sewer & manhole cover for extens
9 Jul 2010
Oxford
Hi. I am getting a little freaked out. I have planning permission for a large extension to the side and rear of my semi-detached house. I did the plans myself on sketchup so we've not had an architect involved. There is a sewer running through the back garden with a manhole cover over an inspection chamber. My plans put this manhole cover in my new bedroom (see photos).
My builder assured me before building that we could lintel over the sewer and install a double-sealed cover in the bedroom - not perfect but not a real problem. The sewer and manhole covers have been built over in a similar fashion on both sides of us.
We put in a building notice application and the inspector has been round and seemed positive.
So far they have knocked down the conservatory and utility room, and are about to start the footings. I got a letter from Thames Water, my supplier, yesterday. They say I need a build-over agreement for any work over a public sewer. More significantly, they say they will not allow you to build over a manhole cover, even with a double sealed cover.
Having read their stuff, I now understand that all shared sewers became public in October 2011, and are therefore owned by Thames Water now. I got the neighbours to flush their loo and it comes through, so I know it is shared.
Anyway, my builder called building control, who told him to contact Thames Water. They said on the phone we will need to divert the sewer but I have no idea how that might work, since it is built over on both adjoining properties already. Their information says 'where feasible Manholes should be removed and piped through. Manholes should be constructed outside your extension'. If they allow me to cover and pipe-through do they also require a replacement manhole? If so there is nowhere to put it as the extension covers the entire run within my property boundary.
Just in case it is important there is a photo of the inspection chamber. The pipe runs 1.40m beneath the manhole and is about 15cm in diameter.
Interestingly as I searched I came across this document which seems to contradict some of the stuff they sent me
http://www.thameswater-propertysearches.co.uk/Views/Common/images/Private_to_Public_Sewers_FAQs.pdf
Page 3 final question says:
"If a property owner wishes to build over a sewer or lateral drain after October 2011 and
there are not any public sewers illustrated on the map of sewers in the area under
consideration for development, what would be the property owner’s position with regards
to requirement of building over approval?
A) Property owners are legally required to notify the local building control department of building
work or works to repair, reconstruct or change the course of a drain or sewer. However there is
no current requirement for the building control office to inform customers or Thames Water that a
building over agreement may be required where the sewer in question does not appear on the
map of sewers. It is the responsibility of property owners to make diligent enquiries to determine
whether the drainage in the vicinity of any proposed development will affect property and to seek
the approval of the owner or owners of the sewers, or drains that may be present prior to
construction."
I checked the sewer map we had done when we bought the place in 2007 and this sewer is not shown on there. Obviously Building control will have the up to date one to look at. This statement seems to imply that it is up to building control rather than TW if the sewer is not on the public sewer map.
I am fine to put in the build-over application but I am concerned about the implications. While I can accept some delay and degree of extra expense, I am concerned that they could simply turn round and say no. If we can't do anything about the manhole, it completely scuppers our rear extension.
Has anyone had similar dealings with TW? Are they reasonable in allowing something to be done that would not have been an issue before October 2011? Am I missing anything important here?
It seems odd that a piece of legislation brought in to simplify maintaining sewers could have the effect of making my back garden a no-go area for extending. Any advice would be extremely welcome. Thanks in advance
Hmmm, that is a bugger.
Since October 2011 it is TWs equipment and they are responsible for its maintenance and repair. You are responsible to liase with TW to get a build over agreement.
It does not look like you can build over a manhole and unfortunately its their rules that you need to abide by. Keep discussing your options with them, it cannot be the first time this has occured and they may have some nifty rodding access solution. Perhaps submitting a build over application will get the ball rolling.
I find that you are in a similar situation as I was 2 years ago. Mine was not a manhole problem but a small sewer carrying 7 houses ran under the corner of my proposed extension. The pipe was checked with CCTV and found to be pitch fibre 40 years old and in a bad way. The water authority wanted me to pay for the replacement of the pipe with malleable iron. (£15,000). I argued that as the pipe was well passed its working life it was their job to replace it. After a year of letters. e-mails etc I finally got them to agree to accept £2000 towards the cost. Looking at yours you could argue that if the manhole in your garden is piped thro' then rodding access is still available from the neighbours property, and as it appears that the sewer is clay pipes, any major problems in the future could be done with "no-Dig" pipe lining.
Hi markwidgery, really interested in this thread - what was the outcome of your issue? Did you end up seeking approval from TW or did you carry on with your build without approval? I'm in a similar situation and also in a dilemma - cheers
No doubt you are long gone, and your extension got done, but I hope you didn't use that builder - he's a t**t.
No doubt he got his extension and when he sells he'll get an indemnity policy to cover it all up. Result. Ignore BAS he talks twaddle. :mrgreen:
Hi All,
Just thought I'd give a long overdue update. Thames Water were surprisingly accommodating. I sent in the application then spoke to their buildover office. They advised a rodding hole with Y-connection into the sewer, then cover over the existing manhole (see new images). This has been done, and all we have sewer-wise in the back garden is a 30cm or so rodding eye hole in the rear garden patio. Small unexpected cost to add on, but in the grand scheme of things not too bad at all.
In case anyone is interested they also asked for specs regarding the footings around the sewer, and I produced these schematics on sketchup with the help of my structural engineer,
Hi All,
I may have a similar scenario, not quite sure.
I am planning for a rear extension too and have been asked to speak to Thameswater for a build over.
As is, there are 2 man holes at the back of the kitchen- 1 in the middle and 1 on the side.
The drains go into the the middle manhole then eventually goes to the side manhole.
The proposed extension will go over the middle manhole - the new drains will connect directly to the side man hole. The middle manhole will be closed - that's the intention.
Could you pl advise if it is an exact scenario like yours or a bit better .
thanks,
RR
Hello, I have similar scenario and worry about it. Has your new plan (rodding hole with Y-connection into the sewer) approved by Thames Water and Building Control? May I have the final drawings as referencer? The pictures you uploaded are too small to see the notes, it would be much appreciated if you can post the bigger size. Thank you very much!
Hi All,
The current BBC TV series Watermen: A dirty business shows just what can hapen if you build an extension over a sewer.
Some chap had to let them come and dig up his bedroom to fix a broken pipe.
My brother wanted to to replace a lightweight 1930s garage with a proper integral garage with a bedroom over it. It appeared that under his garage was an 18' diameter main sewer and he could build over it but a headroom of 9' would be required for the water board to get heavy plant in. The only evidence that there something different going on , was a small cast iron access eye 100' down the garden. Apparently it was a "lamping eye".
Frank
thanks,
RR
Though the OP's manhole picture shows several pipes coming into it, his diagram indicates that they aren't used or important. Your scenario sounds different, as all your drains are meeting at some focal point and heading off, i.e. there's no clear/straight through rodding access. Suppose the drain downstream of your main manhole got blocked, how would you rod it?
Ends up, speak to ThamesWater; you've seen they're amenable and helpful - no one on this forum can give you the approval that they require!
He said so, didn't he?
You are aware that you can click on the picture in his post and see a zoomed version, or click on his name and get access to see his albums for the very big versions?
http://www.diynot.com/network/markwidgery/albums/18685
or email me at ******@gmail.com/quote]
Don't put your email address in posts on the internet.. Edit it out before it finds its way into a thousand different spam Viagra mailing lists.. Doh
:shock: That's a big pipe... They should have just driven the diggers down the inside of it instead
