With the lamp in? Sounds fun
I've certainly used that approach in much more modest situations, but (assuming you mean to leave it permanently 'in circuit', rather than bypassing it after start-up) can one actually get (at all, or for a sensible price) NTC thermistors with a low enough resistance and high enough power dissipating capacity to be used with a 10kW tranny? Even a 0.1Ω (at operating temperature) device would have to dissipate around 160W at full operating current. Maybe such devices are easy to find - I haven't got a clue!Look at NTC thermistors, often these are used to limit inrush current for large transformers, I've used them with some success.
I had the opportunity to ask my brother today ...DNOs must face this problem in a very big way . I wonder what happens when they power up one of their mega transformers - do they just 'accept' the very high 'inrush' current, or do they take some measures to mitigate it?
Thanks. So, in terms of the question I asked, are you saying that they 'just accept' the very high start-up current (simply taking measures to stop it operating protective devices), rather than taking any measures to 'mitigate' (i.e. reduce) that start-up current?I had the opportunity to ask my brother today ... The protection is designed to discriminate for switch on surges - where they have circuit breakers.DNOs must face this problem in a very big way . I wonder what happens when they power up one of their mega transformers - do they just 'accept' the very high 'inrush' current, or do they take some measures to mitigate it?
Fair enough. I guess that exactly the same concept as using a Type D MCB in a more 'modest' situation!AIUI, yes - they just accept the currents and mitigate the effects on protection systems.
And ? You've had a whole weekendGoing to try a couple of different sized heaters first and see if that works as I can cobble it together out of stuff I've knocking around the workshop.![]()
