Hello
Need to run several American 110Volt tools on 220-240volt 50hz supply.
What Kva rating transformer should I get?
Below are list of tools:
* Hilti TE-50 or TE-60
120 Volt 60hz
12.8 amps
So that works out to about 1530watts (using an online wattage calculator)
* Makita or DeWalt Miter saw
120volts 60hz
15 amps
1800 watts
* Makita steel cutting chop saw
120 volts 60hz
15 amps
1800 watts.
I understand that I need to oversize a transformer by about 40% of the max wattage a tool requires.
So would a 3kva or 3.3kva site transformer be enough?
What KVA rating transformer are used in the UK to run tools like the ones mentioned above?
Will something like the below 3.3kva 16 amp Draper work fine for the Miter saws?
NOTE: I only need to run 1 tool at a time.
http://www.ebay.com/itm/MACHINE-TOO...t=UK_Hand_Tools_Equipment&hash=item2a363b99de
Thanks[/b]
120 Volt 60hz
12.8 amps
120volts 60hz
15 amps
1800 watts
120 volts 60hz
15 amps
1800 watts.
Thanks[/b]
