Indeed - and what is that box the cables are going into - is that going to be buried in the wall? If so, assuming it contains 'connections', that's probably not going to be compliant, either.The cables should be run in 'safe zones' when concealed within walls: http://www.diynot.com/wiki/Electrics:walls ... From the photo it doesn't seem that they are?
Looks like a socket backbox to me, so likely to accessible.what is that box the cables are going into - is that going to be buried in the wall?
From the photo there is no doubt whatsoever that they are not.From the photo it doesn't seem that they are?
Thanks - Ah, so it is (and a pretty shallow one at that) - a trip to Specsavers may be indicatedLooks like a socket backbox to me, so likely to accessible.
Thanks - Ah, so it is (and a pretty shallow one at that)Looks like a socket backbox to me, so likely to accessible.
PrenticeBoyofDerry";p="3137200 said:Also by leaving the area uninsulated are you compromising the reason for insulation?
It's an external wall which was uninsulated as it was a garage. I'm knocking it into a games room for the kids and to be fair I'd rather have 100mm of it uninsulated than have to derate or increase cable size.
The wall between the house and garage had been insulated and had two sockets with cables dropped in the partition certainly not touching or fixed to any plasterboard.
They most certainly are. Once the sheet of plasterboard is back on there is a partition going up along the line of the steel beam so they will be less than 150 from the ceiling and corner of the room.
What steel beam?Once the sheet of plasterboard is back on there is a partition going up along the line of the steel beam
Why?I'd rather have 100mm of it uninsulated than have to derate or increase cable size.
What steel beam?
