Wiring 2 way switch help
Looking at the picture the right hand section from the back of the switch operates the hall light and the other is the landing
Looking at the picture the right hand section from the back of the switch operates the hall light ...
As PBoD asked, does that hall light have 2-wat switching (i.e. are there two switches wihich operate it) and, if so, are both switches working as expected?
Remove the cable in L2 right hand gang, and does it make a difference? Remember we are dealing with live conductors so do not work on it live or leave open ended conductors uninsulated.
yes there is another switch on the landing..but i haven't touched that one yet
If that switch is meant to control the hall light, you need to check whether it is working correctly - i.e. whether it can switch the light on when the new switch has switched it off, and vice versa.
ok..i removed the red cable from the right hand side L2 ( from the back ) and the hall light still switches on and off
