I havent used our emmersion heater for a few years as the rocker switch broke and I just use the central heating to heat water. If I replace the switch will it be safe to switch on? Or do they deteriorate having not been used?
That's only the thermostat.It may be an idea to change it anyway to the modern type with cut-out in as well for peace of mind.
"These thermostats are not accurate. They are fairly accurate when they're first installed but when they've been in for a number of years the range of accuracy decreases.
That's all very interesting, although header tanks arent that common these days.
That is a problem with non resettable. Having the manual red reset button is still going to stop the boiling where a thermostat fails but will mean the thermostat does not need changing when the other form of heating causes the over heat only the red button needs pressing.That's all very interesting, although header tanks arent that common these days.
I would think half the houses in my area still have header tanks. My next door neighbour has a plastic header tank and a coal back boiler which regularly boils over![]()
If one was at work yes but at home one could not help hear the noise. OK if very sound asleep maybe but one would have to be very sound asleep the noise is very loud.Dumping 2 kWatts worth of steam into a loft for a few hours can make ceilings soggy enough to collapse.
It's always difficult to say things like this, since "one tragedy is always one tragedy too many". However, in that article the Coroner suggested that 10 million people were 'at risk' of this problem, due to a system which had commonly been present in homes for up to 60 years. If this were, perhaps, the first fatal incident of this type in 10 million people exposed to the risk for 60 years ....!Worth adding to this that in light of the tragic headlines quoted above, The NICEIC recommend that an immersion heater without a over temperature cut out when a plastic header tank is in use, is a recommendation code C2 on an EICR.
That makes total sense. Despite the above, if an electrician (or any other tradesperson) detects a potential hazard, (s)he should at least bring it to the attention of the householder in some way - as well as what we are talking about, that would apply equally to any potential hazards detected in relation to the gas installation, structural issues or whatever. However, as you imply, I'm not sure that it would actually be appropriate to 'code' it on an EICR (although the presence/absence of a cutout is, in some senses, an electrical issue, I don't think that BS7671 addresses it) - although, from what you say NICIEC members may have no real choice.Now I know some will disagree with that, but if you are NIC registered then I think you need to be aware that, that is what they recommend, and be at least noting it down, even if you prefer to change the coding (perhaps you mark it as an observation without a code due to it not being a strictly electrical issue)
131.3(although the presence/absence of a cutout is, in some senses, an electrical issue, I don't think that BS7671 addresses it)
