One of my multimeters has a hold function. This freezes the reading on screen. It is said that it saves having to write the value down while holding probes onto terminals.
It is a hazard, Helping a friend to diagnose why his oil fired boiler was not working I got zero volts across the Live - Neutral supply to the boiler PCB. So clear why the boiler wasn't working.
But for some reason I double checked and then noticed the HOLD button on the meter was on. There was 230 volts on the probes but the meter was "holding" the zero volt value that was on the probes when the HOLD button was pressed accidently and un-noticed.
So if your multimeter has a hold button check the hold function is not operating, especially if you are using the meter to test for dead prior to working on the circuit or equipment.
