The ultra reliable? Intergas 24/18 has started locking out with a code 4 listed. Works OK on both DHW and CH for a while then just locks out again. On resetting will fire up and seems OK but eventually locks out again sometimes after a minute or so other time after a good hour or more. Clearly something is amiss, any clues?
regards
Phil
PS Hmmh. Just done a quick search and someone had a similar problem earlier this year. Their engineer said it was the ignition module which I hear had problems so they changed the design. The problem with that is the new module isn't compatible with the gas valve. So both have to be replaced.
i) Can anyone confirm or shed any light on this and 2) If there is a 'known' design fault aren't the manufactures duty bound to put it right...or have I eaten too many naive tablets!
regards
Phil
