Hello, hope you are well.
I have moved to a new house just under a year ago and seem to have developed a problem with my Garage Lights.
There was two big long strip lights controlled by a single switch. A couple of few weeks ago, one of the strip lights blew a fuse and stopped working. I replaced the fuse but noted that the plastic was very brittle and a bit chard.
Just the other day the same light blew again, so I thought I would replace them both with newer, but smaller strip lights. This seemed straight forward and all worked fine. I also replaced the light switch because it looked old and squeaked as you push the switch in.
Just today the RCD on the board tripped as I turned the lights off in the garage. The new lights don't have fuses so I guess that's why the RCD tripped. The light circuit is not on the RCD protection, just the sockets, shower and EVC Point.
So I looked at what I thought was the junction box that the two strip light wires come from and it appears to actually be a ceiling rose. One of those white circular things you normally see a single light bulb dangling from. It had tape on and was broken slightly.
Now with the two strip lights connected to it, if I flick the light switch on and off about three times, the RCD trips. I have removed one strip light and cannot get it to trip by doing the same tests.
Could this problem be the lack of a proper junction box and the old ceiling rose choc blocks are just don't have the correct rating.
Any advise would be appreciated.
Regards
Dave
Regards
Dave
