I have a Nest thermostat to wire up - the heatlink which goes near the boiler requires 240v and a low voltage switching pair. I have a load of 3-core+earth cable from a lighting project and was wondering if it is a reasonable to use two cores for the supply, and the remaining core plus the earth (suitably sleeved) for the switching circuit?
The alternative, probably more correct way, is 2 runs of twin+earth but it would be nicer with 1 cable
If I have to go with Twin+earth, the heatlink has no earth connection as far as I know, would you connect earth at the boiler end but just snip off at the heatlink end, or snip off at both ends?
