The worst case scenario would be that the problem exists and is caused by water ingress into the wiring which increases the longer the water is running and over time causing a greater risk to the user.
As I precaution i would move the suspect lighting circuit on to the RCD side of the CU. You could install a RCD FCU in to the feed for that lighting circuit ? Much cheaper option and giving you peace of mind.
DS
DS
