Hi All,
I live in a 19 year hold house, soft block walls, chipboard floors upstairs etc., and a while back we had a leak from the cold water supply pipe to the bath in which the water made its way though to the ceiling in the kitchen below. We punched holes through the kitchen ceiling and drained the water into buckets as soon as we noticed the drip so it probably wasn't wet for that long.
I'm now in the process of redecorating the bathroom and while cutting a new skirting board to run along the bottom of the bath panel, it appears that the floor has sagged about 6 mm in the centre although the chipboard surface doesn't look swollen or degraded.
My main question is is the drop likely the result of the water leak and if so is it worth pulling up the floorboards to check the state of the joists underneath or is a 6mm droop expected?
Thanks in advance,
Jools
Thanks in advance,
Jools
