I feel a bit guilty about clicking on the 'New Topic' button as there so much information on here about the topic but if you could spare the time to advise me that would be great.
I have purchased a house with 2 rooms in the pitched roof space. The rafters are 90mm deep 35mm wide with spacing (between) of 400mm. The insulation coverage is approx 45m square meters. At the moment there is some kind of rockwool between the rafters with 3mm plyboard nailed/screwed under the rafters. I'd like to replace this with Celotex or Kingspan type insulation. I don't want to encroach on the room too much. I'm thinking I should increase the depth of the rafters slightly and insulate between them leaving a 50mm gap (due to non breathable felt) and then adding a layer of insulated plasterboard under the rafters. My questions are: -
1. Is it better (or not) to insulate between the rafters, reducing the insulation layer under the rafters? i.e better U value, easier to find screws to fix thinner layer to rafters.
2. About 1000mm down from the peak is my ceiling height effectively leaving a large void behind the ceiling for the length of the room. Does this help the ventilation or affect the requirement for 50mm gap down the sides?
3. When the insulation is installed between and under the rafters, does it just butt up against the floor or does it need to be sealed along this edge?
Any suggestions for a way to go would be great
Thanks for your time
Shaun
Shaun
