Mixer bath tap
29 Dec 2012
London
Hi
I'd really appreciate some advice please.
I don't know whether it's an o ring / washer or whether it clogged up with scale but my cold tap isn't letting water out, all other taps are fine.
I've gotten the top cover off & taken the screw out but can't get any further - do I remove the plastic blue cover (which seems to be completely glued to the knob) or pull the whole tab/knob off (which feels like it's bolted into cement!) Not having much luck with either however it would at least be good to know which one I should be concentrating on. There seem to be mixed reviews on the www.
PS Yes all water is off
You need to wriggling the knob side to side, and pull up. It will come out.
You will need a new tap cartridge.
Daniel.
They still seem to be a mix of lift blue bit / lift whole handle, unless I misunderstood.
So I went to B&Q this morning to see a new handle in operation, & the guy didn't even fully unscrew before the handle popped up! Clearly mine were stuck solid with scale so given that I don't have biceps or a man to call my own, I called in the plumbers!
A young buck with big muscles arrived & even he struggled a bit to get them off. So clearly I had no chance. They are thick with scale & have now been replaced, & I get to wash my hair - yay!
But at least I now know how the taps should work.
Live & learn :)
At least you will know what to do when they go wrong again in about three months time. :lol:
