Hi folks, new to the forum first post seeking advice. Can you help?
I have a Worcester Danesmoor 20/25 Oil Boiler which I suspect is about 18 years old. Since moving into the house 18 months ago there has been occasional water dripping from where the flue pipe enters the chimney. It seems to be coming down the chimney hitting the bottom plate then dripping down around the flue pipe. The chimney is I believe fitted with a circular clay liner (house same age as the boiler).
To rule out rain water ingress I recently had the chimney stack all re-pointed and a rain cowl fitted. The roofer however did say that the stack was in good condition.
Following that came high winds and lots of rain, no problems with water dripping. However now with no wind or rain and much colder outside temperatures after 60 mintues of the boiler coming on the water starts dripping. We only have the boiler on for 5 hours each evening. Last night about half a litre of water dripped until the heating went off when the dripping stopped. Tonight after 3 hours of it on the water has now stopped dripping (not as cold outside).
So this leads me to suspect that the issue is due to the combustion products condensing on the chimney walls. Especially in cold external temperatures and little wind and possible low up draught. Am I on the right lines?
If so how can the problem be cured?
What kind of specialist tradesperson should I seek for advice? I am at a bit of a loss and any advice will be much appreciated. I am even wondering if the chimney might need a brush up it to ensure no partial blockages before spending a lot of money.
Oh our boiler was recently serviced and deemed in good condition for its age.
Cheers
Craig
Cheers
Craig
