Hello all
My garage is badly needing the electrics sorted on it.
The garage is built onto the side of the house and was added about 20 years ago along with a rear extension to the kitchen.
A new hagner consumer unit was fitted in the house about 5 years ago, it has a row of normal mcbs for lights etc and then another row that is protected by rcd for sockets etc.
Currently there is a 2.5mm cable with a 32a mcb on rcd side feeding the sockets to the garage and extension. there is two live wires coming out the top of the mcb suggesting a ring however the sockets in the garage come to a dead end after 5 double sockets, maybe it's 1 radial to the extension sockets and another radial to the garage sockets? would that mean 32a poses a fire risk?
The lights for the garage and extension is a 1.5mm cable coming from 6a mcb, there is just one live cable going into the mcb.
What i would like is a separate small consumer unit in the garage doing the lights and sockets, however i would like to allow for some future 16 sockets, maybe a nice new planer/thicknesser and air compressor
The new cable feeding the garage cu would need to go under the floorboards (joisted floor construction and non insulated) for about 8 metres to get to the garage, probably about 11 / 12m in total.
I'd like to do most of the labouring work myself to save some money so my questions are what size cable would be recommended to feed the garage cu ? And would you advise armoured?
