Not even if you nip them up a bit with a pair of pliers?
M3.5 screws will not go into 4BA threaded lugs![]()
I suppose I would as well, given my feelings about MF joints - but I suppose that has to be traded off against one's feelings abut the aesthetics of the additional blank plate. However, if the OP were fairly lucky, there would be enough slack in the cables not to require any joints - I did say "(extending the cables with MF JBs if really necessary).Personally I'd rather see a screwed joint behind a blank plate than an MF joint shoved under a floor.
Strange, I've done it before. Better to get 4BA screws however.
Remind what 4BA is.
Oh, I see - how extraordinary!The old double socket was half behind a brick fireplace so only one socket was accessible.
4 B.A. has an outer diameter of 3.6 mm, and uses a tapping drill of 3.0 mm. Threads per mm is 1.514.Remind what 4BA is.
So slightly smaller, hence my idea about nipping it.4 B.A. has an outer diameter of 3.6 mm, and uses a tapping drill of 3.0 mm. Threads per mm is 1.514.
3.5 mm has a tapping drill size of 2.9 mm, 0.6 threads per mm.
A rethreader would be best, but I bet a stainless steel screw would self-tap its way through a mm or so of mild steel...So the diameter is similar but the thread pitch will screw you up (sorry).
