Britony II T knowledgeable engineer required
20 Jan 2015
London
Hi Guys
Is there any engineer available to repair my Britony II T water heater.
The issue is pilot light goes out when the hot water tap is turned on.
What I require is an engineer who has knowledge on these boilers and is happy to repair them.
I am based in Kingston Upon Thames.
Good little water heater in their day, as your post suggests a lot of engineers these days are only interested in central heating, you might be better contacting the makers Chaffoteaux, I think they are part of Ariston now.
When I was working (15 years or more ago! )I used to get my Chaffoteaux parts from here
http://www.cylex-uk.co.uk/reviews/v...ame=saglio-boiler-services&companyId=15746499
Might be worth a ring, to see if they still deal with them, Kingston might be out of their area though, still they may be able to suggest someone in your area if they are still doing Chaff bits.
It would be better to put your postcode here.
In case someone like me would want to see how close it is to the 57 bus or other transport.
Whilst I could get there, as its very old, the chance of seized screws is very high as well as the difficulty of getting spare parts. Although your description of the symptoms would indicate that it would normally be a relatively simple problem.
It would be far better for a local engineer if you can find one willing to work on such an old appliance. As I would be charging a diagnostic fee of £94 you might also consider if it would be better to bite the bullet and replace it.
These kind of gas only operated water heaters have been very reliable but the current tendency is to us electrically operated units which are virtually a normal boiler but they don't seem terribly reliable. There is a post today about a Baxi one giving problems which has already had a new PCB fitted last year. Most of the old ones work for 5-6 years even if they are not serviced as they should be every year.
Tony Glazier
Thank guys for replying back.
As you both have said these are great reliable water heaters. The water heater only supply hot water to a kitchen sink and wash basin, never used to fill the bath so in general only very light use.
Even if I were to change to a new boiler i feel these would cost more to repair in the long run due to the PCB failures and the cost of the new boiler replacement.
I have spoken to Ariston aready and seem that the problem is either with the gas flow into the boiler or diaphragm.
I have had engineers out in the past for a service and I never feel confident that they know what they are doing. So hence I thought I would try and find a Knowledgeable engineer who know how these boilers work.
I have checked online and it seem most parts still able at the moment.
Just to advise the post code is KT2 7RU and the 57 bus stop is about 10 mins walk. If it would help I may also be able to provide some transport help.
Is parking that bad in K.U.T.? :shock:
If you don't find anyone local then I might consider coming on the 57 bus.
By chance I will be using it on Thurs evening.
Tony
Tony
Hi Tony
I have not been successful in finding anyone. So your help would be much appreciated.
Thanks again.
I will message you my contact details.
All sing along now.
The plumbers on the bus go splash, splash, splash, splash, splash, splash.
The plumbers on the bus go splash, splash, splash.
All day long
The wheels on the bus go round and round..................
Feel free to add verses for other trades!
I know it should be Gas Safe Engineer but somehow it just don't work so well
:D :D :D
So that will be £94 plus BFH?
Hi Rob
Tony has not yet been able to come out and have a look yet. If it is not feasible for him to come out and have look. I will give you a call.
Whats your contact details?
Thank again.
well its reassuring that even ariston tech dont even have a clue :roll:
Hi Rob
Thank again.
I've included my email in my profile
diaphragm???
Gas flow: Pilot supply filter?
have I said too much?
Yes :lol: lets just say its not the gas flow into the boiler but a gas flow problem of some sort :wink: .... diaphragm :roll:
