- Joined
- 27 Jan 2008
- Messages
- 27,694
- Reaction score
- 3,356
- Location
- Country
As far as I was lead to understand the IET/BSi panel had very little choose in including the extra fire protection measures.
It would seem extreme pressure was put to bear manufacturers were just too slow altering their products to stop the massive increase in fires so the result was a change in regulations.
We have all made comments on what could have been done to reduce the fire risk but it simply was not done.
As to the other fire related alterations I will admit I have considered escape but not re-entry by fire fighters. And the use of steel cable ties has been common practice in the petrol/chemical industry but no so much in the domestic installations.
I have used trunking myself and to stop it falling off the wall latter used decorators cork. I am sure many others have done the same. And that includes going over door ways. That will no longer be permitted and clearly this will affect many aspects of the trade specially things like intruder alarms and LAN cables.
Where the problem arises is doing an EICR failing the installation due to SELV cables be it telephone or alarm is questionable. And what code will we give it? Clearly we will modify what we do but it will also need allied trades to do the same.
