Blue smoke is oil.
I wonder if as Mursal said, you have excessive end float (caused by worn thrust bearings as I said earlier). Cornering hard might (I don't know but it would seem possible) throw the crankshaft far enough over to make the rattle. Bearings worn on one side would give the effect of only making the noise on a right bend . . .
Causes of worn thrust bearings here
http://www.4secondsflat.com/Thrust_bearing_failures.html
which includes torque converter probs. if you read down.
Whatever I'd drive it pretty steadily until the cause is known.
