Hi.
At my house I just moved in, with a garage about 15 metres away.
Info:..
In the garage, there is sockets and lights. All cables is in round trunking. Lights and power all goes to two way fuse board with MCB each, no Rcd.
At the moment there is no power. On finding why, i found the cut cable inside waste pipe attached to house side, reason unknown.
Is it possible to replace main cable between house wall and garage wall which has the same waste pipe attached to garage wall? With new 2.5mm or....?
Also rather than wiring it into a ring final,I will be putting in 2.5mm cable to run from house fuse board to a fuse spur where the main cable come through wall. It will be about 12m long, will it be okay?
I will dig a few holes to find out if the waste pipe does goes all the way.
I will be reducing to a double socket and a light as I don't need much.
Many thanks for your help.
Daniel.
Info:..
Daniel.
