Even if there is enough slack in the cables, getting them across/through the joist in a safe and reg-compliant fashion would not be a trivial/ straightforward exercise. Those two grey cables in a notch in the right-hand joist, just under the edge of flooring, are potentially dangerous (at danger from nails etc.) and not reg-compliant - and that's certainly not the way to do it. I'd be inclined to just leave things as they are - but put some adequate metal protection over those notched cables I've just mentioned.I think I'll put the wiring in the left channel.
The wiring in the picture does not look nice, it's like a rats nest, but are any regulations being broken? Thanks.
Two of them are notched in the topof joist by the look of it. You can get armoured plates that go over them to protect them
Indeed ...If you're sticking with cables notched into the tops of the joists, try to move them over so they aren't where one would expect the nail to penetrate.
Those two grey cables in a notch in the right-hand joist, just under the edge of flooring, are potentially dangerous (at danger from nails etc.) ... put some adequate metal protection over those notched cables I've just mentioned.
No problem - it never deos any harm to show that great minds think alikeI just knew youd say that johnId only read the first posts, The pics so big you were off the page when I replied then it was too late
Indeed - if they were cut 'in situ' (which they may not have been), then whoever did the cutting (which, of course was not necessarily the OP, given that someone had previously installed the pipes and cables) must have used a clever depth-limited sawing device (and got the setting just right!). Mind you, we cannot tell for certain from the photo that the cables are totally intact at the point of the cut - the OP certainly ought to check that, if he hasn't already!Im intriqued he never sawed through them
I inherited something very similar (paint, not Sharpie) on floorboards under the carpet in many habitable rooms in my house. As you say, not ideal, but far far better than without the 'warning markings'.As an aside, this caused me to recall that my attic has similar notched rafters just under the flooring. We moved in around three years ago and I noticed that the previous occupant had used a sharpie / marker to trace the route of the cable across the flooring with "MAINS!" written every foot or so. So not an ideal situation but at least he seems to have mitigated against the most obvious dangers.
