Replace Potterton room thermostat with programmable version
1 Sep 2013
Essex
Hi All. I have a basic Potterton PTR01 thermostat that I would like to replace with a new programmable version (Honeywell or Heatmiser PRT-TS?).
The existing thermostat has 3 wires connected (red-L, blue-N and yellow-Light Symbol) plus an unconnected earth. I want to avoid replacing this in wall cable but am not sure if it can be used with the new programmable thermostat?
My setup consist of a Potterton Suprima boiler and Boilermate II hot water storage unit.
Would appreciate any advice.
Do you have an existing timer/programmer? If so, which one?
Are you thinking of a wired or wireless programmable stat?
There is a very basic timer on the Boilermate II which allows me to set on off times but cannot vary this for different days. So I assume I just set this to on all the time and then control from the thermostat.
I thought a wired one would make sense as the cable is already in place. Just not sure about how the wires will work with the new programmable thermostat.
Yes
If you use a Honeywell CM907 connect as follows:
Red to Terminal A
Yellow to Terminal B
The blue and earth wires are not required and should be made safe, e.g in a terminal block hidden behind the back plate.
NO connection should be made to terminal C.
