TOILET CISTERN WATER INLET LEAK
Toilet cistern leaking from water inlet flexi hose threaded pipe section that goes into plastic nut bottom of cistern bowl. keeps dripping down onto flexihose. Tried fornex ls-x to try and seal- not working.
Need to change the flexi hose what dimensions do I need to measure on existing one so I know what replacement flexi hose to ask for please.
looks like 15mm pipe thickness, 25mm end connector nut size
and length 300mm
is there such a flexihose available ?
Also is it ok to use fornex lsx on the threads when fitting new one.
Regards,
Phil.
and length 300mm
Regards,
Phil.
