Do you have the version that has different settings on the control box? There are some that can be set to pumped or combi. Can you hear or feel the pump working?
have you checked power to the unit? Is there a fuse anywhere on the supply. Have a look at the link that I posted above as it gives some common faults including reduced flow. If no joy, it might be worth contacting Aqualisa.
