Moved in to refurbished/replastered Victorian terraced home in mid 2013.
In the front lounge, north-facing bay window, there is damp or condensation. See diagram attached.
These walls are very cold. We don't see window condensation, but also don't much think there is water coming in (windows and base of wall were resealed, mid 2014). Window sill board has swelled a bit, however.
What is the solution?
We plan to carpet the room, which currently has bare floorboards. This may raise the temperature. Also, we will get better home heating thermostat control, as we yo-yo the radiator between on and off at the moment.
Mid 2014, during other work, a contractor filled some areas at the left, but these have partly degraded since.
Quotes we have received:
Quote 1:
Quote 2:
Thanks for your advice.
Quote 1:
Don't think we have the stomach to remove plaster all the way to top of wall - seems fairly radical and expensive, even though I understand why plasterboard would warm the room.The removal of exiting render, plaster, and picture rail.
• The applying of damp proof coating to outside walls at lower level up to a 1m high where possible.
• The fitting of insulating plaster board.
• The plastering of new boards.
• The fitting of picture rail and bay fillets.
• The painting of complete living room walls (This will be necessary if all work goes ahead).
Total cost - £1500
Quote 2:
More modest disruption and cost, but don't know if it will do the job. He spoke about getting a dehumidifier on timer during the winter.Prepare wall, fill and sand, apply coat of anti damp paint , over paint with 2 coats of emulsion, seal window and spray exterior wall with silicone based water proof solution. In the sum of £440.00.
