DIY Building an Extension & Building Control
5 Apr 2012
In and around London
Looking for advice from anyone with experience of conservatories and small extensions...
Let's say a conservatory or extension doesn't need planning permission as it does not exceed the conditions set out.
Presumably it will still need to comply with any related building regulations, and generally be a safe fit for purpose room. So, for the purpose of this question we can take it as given it will be built to comply with building regulations and to correct specifications, but my question is what aspects of the work would actually require a building inspection?
Obviously, any electrical work will be new installations and as such, Part P notifiable work needing to be inspected. The same would apply to glazing and Part N. Is there anything else that would need to be inspected/notified, given that the room will probably just be a dining area? Or would the work in its entirety still need to be notified anyway?
I suspect they'd be interested to know that the structure won't fall down, catch fire, suffocate its inhabitants, or significantly aid global warming.
Yes.
It's not notifiable if it's an exempt conservatory, is it? That is, it's (a) a conservatory, which is generally understood to be a mostly glazed thing with a translucent roof, and (b) it's exempt, by virtue of being less than 30 m2, being separated from the house by external doors and not on the house heating system.
For which see endless discussion in this forum (search for "exempt conservatory").
Cheers
Richard
Unless you can knock it up in a month, as of 6th April, all projects are notifiable.
Actually, it's more complicated than that.
A project is notifiable if it's scheduled to last more than 30 working days (so 6 weeks) AND have more than 20 workers working on site at any point (admittedly unlikely on a conservatory extension).
However, it's also notifiable if it's scheduled to exceed 500 person days - so a project with 11 people for 45 days, for instance.
Here's a handy calculator:
http://www.darleypcm.com/cdm/cdm-2015-notification-calculator
