Cordless screwdrivers
21 Jul 2010
Weymouth, Dorset
I'm in the market for a 10.8 drill driver without chuck for screws only. When I look around there seems to be a lot of difference between torque ratings. For example, hitachi make one that only has 10nm, whereas the Bosch equivalent has 30nm, then Festool CXS is about 16nm.
Is a high torque really necessary for regular wood screws?
It depends on how big the screws are, whether you drill pilot holes and what the material is you are screwing into. 4*50 into piloted softwood isn't going to be a problem. 6*100 straight into oak is another matter.
If you don't want a chuck why not an impact driver? 80Nm upwards from a 10.8V.
Probably only softwoods and MDF....don't go near hardwoods. I would probably drill a pilot for very large screws, so torque really doesn't become a problem then. Your answer is what I thought really.
Also some manufacturers torque rating are slightly different in the way they market it. So a dewalt with 65nm of torque does not necessarily have less torque than a makita with 85nm of torque. Makita all the way of course though! :)
Ended up buying two Hitachi 10.8v, one drill driver and one screwdriver, plus three batts. They work very nice and the drill driver is quite powerful.
